Emission Test Failed...
Old Jan 20, 2011 | 02:19 PM
FuGativ3's Avatar
Old Jan 20, 2011 | 03:13 PM
himike's Avatar
Originally Posted by Kieran650@msn.com,Jan 20 2011, 02:38 PM
MAYBE IT WASNT FULLY WARMED UP WHEN YOU BROUGHT IT DOWN. SOMETIMES THEY WILL FAIL YOU IF YOU EMISSIONS SYSTEM ISNT PROPERLY WARMED UP WHEN YOU GET TESTED BECAUSE THE SYSTEM IS RUNNING RICH OR APPEARS SLOW TO RESPOND.
Old Jan 20, 2011 | 03:27 PM
himike's Avatar
Originally Posted by FlushNFR_S,Jan 20 2011, 12:31 PM
So I'm starting to think this car is actually bad luck...
Hope the car's not bad luck for you..... When you get all that stuff fixed, you'll enjoy the car!
Old Jan 20, 2011 | 04:50 PM
Fastfour's Avatar
I'm also able to clear codes. I'm in Shoreline and if I can help just let me know.
Old Jan 20, 2011 | 05:16 PM
blacknwhite's Avatar
For $100 I can remove your current ecu and replace it with one from a chevy luv. You won't have any more cel problem I promise you. Just let me know...
Old Jan 20, 2011 | 05:35 PM
JawKnee's Avatar
Can also read and clear codes. Newcastle area.
Old Jan 21, 2011 | 07:40 AM
himike's Avatar
Old Jan 21, 2011 | 08:44 AM
Fuman's Avatar
thanks, good to know! I have an emission test going on as well.
Question, there is no timestamp associated with the codes?
Old Jan 21, 2011 | 02:56 PM
FlushNFR_S's Avatar
I don't know if clearing my codes will work; unless it doesn't come back for awhile, at least an hour or so for me to get over to the emission test and get it tested with cleared codes.
I most likely will have to replace all my O2 sensors which sucks.
I don't know if I should pay for new O2 sensors and replace and pay for the registration or just pay a friend $200 for him to just register my car with new tabs...
Old Jan 21, 2011 | 03:14 PM
turbo_slug's Avatar
i'm pretty sure those aren't old codes...the ecu will clear itself if the problem disappears for a long enough period...
are those codes stored as pending or are they active codes? if they are active, your check engine light should turn on.
do you know if you check engine light even works? when you first turn your vehicle on, the car does a self check and the CEL should turn on for a brief moment then turn off. if you don't see it go on, someone probably removed the bulb from the gauge cluster
