Photography and Videography Tips, techniques and equipment for taking great photographs and videos. Come here for advice and critique on your photos and videos. To show off your S2000 go to The Gallery
100mm macro-anyone else have AF Issues?
Old 03-22-2014, 04:38 PM
iDomN8U's Avatar
Default 100mm macro-anyone else have AF Issues?
I have a Canon 100mm macro IS F2.8, when the focus is near 1:1 but the subject is a few meters away and OOF the auto focus doesn't kick in. I have to manually bring it to focus then the auto focus begins working again.
Anyone else have this issue?
iDomN8U is offline
Old 03-28-2014, 08:49 AM
iDomN8U's Avatar
Fix: Change the custom settings to not give up on A/F (can't remember the exact term)
iDomN8U is offline
Old 03-29-2014, 06:46 PM
Lainey's Avatar
Received 2,796 Likes on 1,638 Posts
Hmm more detail if you can, especially as to your fix. I have the same lens. I have had issue when the AF has not worked. I'm assuming the camera is confused as can happen, if it is not sure where you want to focus. With the kit lens I'd get the sound of the camera trying to focus, but not being able to, don't think I've noticed it with this lens.
Just of out curiosity are you using a tripod? I struggle a bit with this lens...especially when up close and personal.
Lainey is offline
Old 03-30-2014, 03:18 PM
iDomN8U's Avatar
I have a Canon 5D Mark II
Under Menu
Custom Function III: Autofocus/Drive
Lens drive when AF impossible
0:Focus search on
1:Focus search off
Set it to 0N (this will put a 1 under the 7)
It will continue searching even when your extremely OOF.
iDomN8U is offline
Old 03-31-2014, 03:16 PM
MisterNickG's Avatar
Switch it from Full to Limit. See if that helps.
Thanks
EDIT: Nevermind, just saw the OP found a fix.
MisterNickG is offline
Old 03-31-2014, 03:58 PM
iDomN8U's Avatar
Thanks
You are right both need to be set for optimal performance. In my case the full range did squat
iDomN8U is offline
