beginner studio lighting setup
if i wanted to setup a simple beginner studio lighting setup in my basement what would I need? bare minimum to get started but something that I can continue to add on to so I don't outgrow it
http://www.bhphotovideo.com/c/product/4252...ella_Mount.html
http://www.amvona.com/?page=shop/fly...roduct_id=2288
This kit is affordable and great starter kit, you can add more stands and strobes later. Also, take a look at Alienbee's ringflashes, they are great for portrait work.
http://www.alienbees.com/abr800.html
Originally Posted by jtpassat,Jul 16 2007, 11:22 AM
so you'd use the ring flash with the umbrella?
http://mpex.com/Strobist/StrobistKits.htm
Originally Posted by pointa-b-c,Jul 16 2007, 02:53 PM
No, I don't have that Alienbee ring flash, but it would be nice to have. I have seen great results from Alienbees and they are pretty affordable as well. For my current setup, I only shoot with 2-3 flashes, combining with umbrellas and diffusers. I will eventually purchase another softbox or an octobox depending on what jobs are coming in. So I think you can definitely build up your setup without outgrowing it. Also, you can take a look at these, if you don't have flashes to already.
Bare minimum? One strobe and a reflector. The trouble comes when you try to define the exact equipment.
If you want portability you can get quite a set-up going with Nikon's iTTL speedguns (standard camera flashes).
If I was setting up more of a permanent studio space, as a talented amateur I'd be most tempted by those Alien Bees monolights or their new pack-based system. Paul Buff seems like the kind of businessperson we should support. He is active on the DP Review forums.
What would I REALLY want to do people right? Three strobes with modeling lights and stands -- one key, one fill, one hairlight (with snoot and/or grid), big softbox (if I want soft I want really soft), two umbrellas (for key & fill), and a beauty dish (ringlight might be easier but also harsher). Then I'd want background stands and muslins (hand-painted seems easiest) or seamless paper plus posing props (stool, table, etc.).
and I am learning this whole "studio lighting" and flash photography, learning curve is rather steep and requires much time and experiments.
Here you can find some good info if u look more into setups, kits, the whole 9.
http://www.studiolighting.net/
