Prairie Redliners Canadian Prairie Provinces. Alberta, Saskatchewan, Manitoba
Floor jack
Old Feb 16, 2008 | 05:21 PM
Murray Peterson's Avatar
Default Floor jack
Does anyone have a floor jack that they would recommend (and where to buy it in town)? I tried a nice looking one from Auto Value, but the 5 inch minimum height is to high to fit under the side jacking points.
Old Feb 16, 2008 | 09:44 PM
4doorj's Avatar
I saw one at walmart, it lowers about 3" something.
Not to sure how good it works, but it should be okay.
Usually what I do is use a regular jack and just drive up onto a piece of wood.
Old Feb 16, 2008 | 11:25 PM
shox's Avatar
Or use the stock jack in ur truck to lift one side of the car and then slide the floor jack underneath
Old Feb 16, 2008 | 11:30 PM
slackfaster's Avatar
I have a nice 5-ton floor jack w/ a minimum 5" height...
so i drive up on a couple of 2x6 and everything is cool.
Old Feb 17, 2008 | 06:45 AM
Yeah, that seems to be the norm. Buy a cheaper jack and just drive up onto some 2x6's to get the car up high enough. Or use two jacks.
Yesterday I found a nice 1.5 ton aluminum jack from Auto Value ($78) that goes down to 5" instead of 5.5". It's still a bit too high, but if I take the front rollers off it just barely fits. It takes a tiny shove to get under the side hardpoints, but that's just the rubber saddle pad grabbing a bit. I'll shave the rollers on a lathe and I should be good to go.
Old Feb 17, 2008 | 09:09 AM
I only jack from the front and back...
so I'm not sure about the side...
(I use the side points for jack stands)
Old Feb 20, 2008 | 09:22 PM
MikeyCB's Avatar
I bought mine at Canadian Tire. Princess Auto has one that drops to 2.5" I believe. Pricing isn't too bad on it either, check it out on their site.
You really don't need anything more than 1.5 ton as you aren't lifting the entire car up. It's more than enough.
My CT jack cost me $24 and has worked flawlessly. Not heavy either.
Old Feb 28, 2008 | 11:15 AM
Jonanator's Avatar
I have a CT Low profile jack that has been great so far *knocks on wood*
Old Feb 28, 2008 | 02:08 PM
4doorj's Avatar
i bought the one at walmart... i have no complaints...
its not as nice as the princess auto one.. but its pratically 1/4 of the price
Old Feb 28, 2008 | 08:06 PM
undeRwhelmed's Avatar
I second the Princess Auto jack. They have 2 different size low profile aluminum ones (the brand is Powerfist). I bought their smaller one for autocross and is works great and was less than $100, is quite light and fits under a stock height S2000. If i wasn't karting it around (ie: just in the garage) i would have bought the bigger one, as it lifts higher.
RV6pilot
13
Apr 17, 2006 08:35 PM
revto9k
Oct 3, 2004 05:18 PM
heffergm
Dec 30, 2003 07:05 AM
netwiz
Feb 22, 2002 12:08 PM
tram57
May 22, 2001 03:35 AM
