S2000 Body and Paint Body kits, paint, ding repair and related discussions
Anyone have this problems
Old Oct 14, 2013 | 06:53 AM
iwants2know's Avatar
Default Anyone have this problems
My top doesn't really close all the way
Sent from my iPhone using Tapatalk - now Free
Old Oct 14, 2013 | 07:00 AM
S2KIrishman's Avatar
yes, yes I do...and its annoying as shit because of the wind noise and if it rains really hard, it leaks pretty good...never been able to figure it out, I just chalked it up to a bent soft top frame
ive tried the whole shim thing on the strikers and even got the updated hard top strikers to try and fix it, but nothing has worked
Old Oct 14, 2013 | 07:04 AM
RedCelica's Avatar
yep and figured out how to fix it too. I accidentally forgot to latch my top and was on track @ 80 mph when it popped open.
Fix:
With the front portion of the top at about 45 degrees, manually pull the top down with both hands evenly distributed. Once all the way down (to the seal), retract the top using the electic switch/motor. This will realign the frame and it should close fine after that. Repeat if necessary. Mine was fine for about 3 weeks and then I had to do it again...all good for the past 4 months now
Old Oct 14, 2013 | 08:29 AM
Thanks gotta try that soon
Old Oct 15, 2013 | 03:06 AM
xoz's Avatar
xoz
Fix:
Didn't know about this, as have never had the problem. Definitely good info. Thanks.
Old Oct 16, 2013 | 01:07 PM
so how do you pull the roof down manually since you'd be fighting the motor?
Old Oct 19, 2013 | 05:40 AM
You will need two people one to pull the top and one to press the button make sure it's even force cuz the top won't be even and btw it work no more gap thanks a lot again
JulioOchoa23
Nov 2, 2014 04:53 AM
instinct
Jul 19, 2014 06:00 AM
hansai00
Nov 4, 2008 08:06 AM
blue LS
Apr 21, 2005 10:32 PM
