S2000 Body and Paint Body kits, paint, ding repair and related discussions
Rear window replacement
Old Apr 7, 2013 | 03:12 AM
Harrylennon's Avatar
Default Rear window replacement
Hi, It was a nice day yesterday so I decided to try the roof out, as it folded down the plastic window split down the middle..
My roof is in good condition so i want to just replace the screen. Has anyone had to replace this? I'm hoping ill be able to do this myself..
Thanks..
Harry
Old Apr 8, 2013 | 10:27 AM
NDAZONE's Avatar
It can and has been done. Do a search and good luck. I believe it zips out.
Old Apr 8, 2013 | 09:40 PM
s2ka's Avatar
I did mine earlier this year. The back section with the plastic window is available from Honda, I think I paid $200 for mine. The upper part unzips but the lower part is pop-riveted and sandwiched, so you have to remove the roll hoops, rear tray, center console, seats etc. to do the job properly. The good news is that you don't need to remove the front section from the frame so it's a little easier than a full top replacement. But it will still make you curse the Honda gods several times.
Installation is pretty much like this except you don't need to remove the front half from the frame:
https://www.s2ki.com/s2000/topic/882...t-diy-for-my02
Old Apr 8, 2013 | 09:53 PM
savages2k's Avatar
Does anyone know if the glass window is replaceable? Mines shattered while opening it the other day.... It was only 2 months old!!
Old Apr 9, 2013 | 03:44 AM
Thats Great thanks for the link, very detailed guide! I also found this,
https://www.s2ki.com/stor/library/TSB/A00-048/index.htm
Im sure the glass window is replaceable ive seen some threads about on here..
Thanks
MPS2000
Nov 9, 2011 05:43 AM
Bingoig11
Aug 20, 2010 03:00 AM
Bassoctopus
May 9, 2008 08:00 AM
SolReborn
May 27, 2004 05:06 AM
Iceman
Aug 13, 2001 01:21 PM
