Bleeding Stoptech
Stoptech's installed. Can't get a firm pedal. Tried old fashioned bleed with two people and also tried vacuum bleed. Pedal still soft. Is there a special way you are supposed to bleed these?
Thanks
Thanks
Hey pete!
When I installed my Stoptech kit I had to bleed several times before I could get a hard pedal. Like Mac mentioned go drive the car (if you can) to an empty road and really slam the brakes with the intention of staying in ABS as long as possible. After a few times go home and re-bleed. Repeat until you get all the air out.
Also when you bleed the calipers start with the outside then do the inside nipple.
