Sponsored by: Sake Bomb
Bleeding Stoptech
Old Aug 16, 2013 | 05:23 AM
petegemelli's Avatar
Default Bleeding Stoptech
Stoptech's installed. Can't get a firm pedal. Tried old fashioned bleed with two people and also tried vacuum bleed. Pedal still soft. Is there a special way you are supposed to bleed these?
Thanks
Old Aug 16, 2013 | 05:32 AM
macr88's Avatar
Did you bleed the inside and outside section of the caliper?
Old Aug 16, 2013 | 06:10 AM
Several times now
Old Aug 16, 2013 | 07:04 AM
macr88's Avatar
You might have air in the abs unit, soft pads? There's plenty of other possibilities though.
Old Aug 16, 2013 | 07:33 AM
What do you mean by soft pads? They are pagid rs29. The pedal feeling is definelty not from a soft pad it has to be air.
Old Aug 16, 2013 | 07:50 AM
macr88's Avatar
Then air in the ABS unit, you'll need to engage the pump then bleed then engage again and bleed until the pedal feels right.
Old Aug 17, 2013 | 09:15 PM
MMisencik157's Avatar
Hey pete!
When I installed my Stoptech kit I had to bleed several times before I could get a hard pedal. Like Mac mentioned go drive the car (if you can) to an empty road and really slam the brakes with the intention of staying in ABS as long as possible. After a few times go home and re-bleed. Repeat until you get all the air out.
Also when you bleed the calipers start with the outside then do the inside nipple.
Old Aug 20, 2013 | 02:49 PM
chuhsi's Avatar
have you tried gravity bleeding? worked great on mine.
ktwenty
Aug 22, 2014 01:05 PM
FREEK
Mar 28, 2012 03:40 PM
Boost-Me
Jul 3, 2011 06:53 PM
dan_uk
Sep 21, 2009 08:50 AM
1.8TsBLOW
Feb 15, 2008 01:29 PM
