soft brakes after brake caliper replacement!
I replaced my two front calipers as one was sticking, however after following the standard bleeding procedure using those vacuum tools I can't seem to get the brake pedal hard! I'm following the sequence and using grease at the nipples to prevent air from getting in, did the sequence 3 times and still a soft pedal! Very soft! What could be the issue? Vehicle is rhd though
Did you make sure your rear brake piston slots are lined up correctly with the new pads? It's been a while since I did my last brake job but I recall that it has to line up or the pads will be loose.
