Sponsored by: Sake Bomb
ground control spring rate question
Old Apr 14, 2013 | 02:50 PM
dsthez's Avatar
Default ground control spring rate question
I'm looking to lower my s2000 about an 1" front and rear. I dont want to go with eibach pro kit cuz I have a feeling it won't drop to my personal preference. So I want the adjustablility of the ground controls to make my ride height spot on. What spring rates would I want to get a stiffer ride but not bouncy. Stock spring rates for a 2003 is f240/r230. It looks like the pro kit runs f260/r340. I want stiffer than stock but I don't want to bounce. Any recommendations?
Old Apr 14, 2013 | 03:16 PM
OG35Z's Avatar
I would get as close to the CR rates as possiable. That is assuming you do not want to go higher.
Old Apr 14, 2013 | 09:26 PM
MrChoi's Avatar
i went from 515 in/lb to 350 in/lb on my kw's. closest rate to CR is 375F and 350R if I'm not wrong. You may have some trouble having the springs sit correctly on the stock spring perch.
Old Apr 15, 2013 | 06:26 AM
Ouhei's Avatar
I'm confused, are you going to be running GC coilovers on stock dampers? Or are you going to go to a Koni shock?
Old Apr 15, 2013 | 08:42 AM
dsthez's Avatar
Stock dampers
Old Apr 15, 2013 | 09:42 AM
Ouhei's Avatar
I definitely wouldn't go over 400lb springs then, if you're wanting a little stiffer than stock I'd say CR rates would be good. If you go too high it's going to get bouncy because you'll be over sprung (too stiff a spring without proper dampening to compensate).
Old Apr 17, 2013 | 07:24 AM
dsthez's Avatar
Should I just go with Megan tracks instead?
Old Apr 17, 2013 | 03:31 PM
faiclub's Avatar
Megan track has much higher spring rate, don't they? Of course they also come with dampers that are valved for stiff springs but I am guessing the ride will be very different from using stock dampers and GC springs.
I am also looking at getting the GCs (koni shocks + spring), and I wonder how they compare to full blown coilovers like KW V3s or TEIN Mono Flex, etc. GCs are much less expensive.
Old Apr 18, 2013 | 12:55 PM
OG35Z's Avatar
I had the Koni/GC setup with 550F and 500R spring rates. It was great for the price and for Autocross. Not sure it would make a good DD setup. I had mine set up pretty stiff shock wise and since I did not DD the car I left it that way all the time. I suppose on full soft it mide ride closer to stock.
Old May 3, 2013 | 10:40 PM
speedjunky01's Avatar
I have the GC Koni combo and their autox recommended rates . Believe 550 and 450 if memory serves, the ride on full soft is stiff but soaks up street bumps very well on full firm it was track only for sure way to stiff to soak up bumps.
Ride was better than my buddies js racing coilovers they couldn't take a bump to save their life so damn stiff. The car would lose grip and skate across the road if God forbid there was a crack in the road halfway in a corner. No such issue with the GC Koni combo I dd mine 80 mile a day commute
Apeatwo
May 12, 2012 11:55 AM
Cheers!
Jun 11, 2010 04:31 PM
BatmanCR
Mar 22, 2010 09:56 AM
killerbee_vr6
Feb 19, 2008 02:04 AM
Fastfour
Jan 10, 2008 05:52 PM
