Sponsored by: Sake Bomb
Lower or Keep stock
Old May 17, 2014 | 06:05 AM
Hicktown s2k's Avatar
Default Lower or Keep stock
Hey I have a question for all the people on here that know more than me. I am looking into lowering my car 1" (00 with 104k) and putting on some 18" CCW wheels, my question is can I lower it 1" by just getting coilovers and doing nothing else or is there going to be a need for supporting modifications? My other question is if I lower 1" and go from 16" rims to 18" rims is my car going to ride lower to the ground (less clearance) or would the bigger rims negate the lowering?
Old May 17, 2014 | 07:38 AM
Manga_Spawn's Avatar
Site Moderator
You car should have the same ride height as long as you make sure to buy the right tires and keep the rolling radius of the wheel and tire the same or very close to oem. This is what on a 17x9 you run a 255/40/17 tire and on an 18x9 you run a 255/35/18 tire. In short wheel and tire size should not make the car ride lower or higher as lone as the setup is correct.
As for lowering with coilovers you should have enough adjustment to have stock ride height or scrapping the ground ride height. That's why they are adjustable. You will need a fender roll and tab relo with ccw's unless you buy oem spec ones and that would make no sense.
willyummies_
May 23, 2017 10:06 AM
notstr8
Oct 24, 2007 10:02 PM
JimmyB
Jul 10, 2007 04:34 PM
LAKERFAN1975
Mar 17, 2006 04:01 PM
lalaspanda
Feb 16, 2004 07:01 AM
