Modulo Sport Suspension Questions
Hi, I have an 08 S2000 and I was wondering if anyone could answer some questions about the Modulo Sport Suspension offered by Access Honda.
Were these designed for the AP1?
Have they updated it since for the AP2?
Does anyone know if these specs are accurate? It's the only info I found on them after hours of searching
Specs are:
* -10mm lower ride (fixed)
* 5.1kg/mm front 6.8kg/mm rear springs
* 5 step combined compression/rebound adjustability at the front so that you can tune over/under steering handling characteristics
https://www.s2ki.com/forums/index.ph...owtopic=125335
Will this lower an AP2 by 10mm as well?
According to an OEM spring rate thread. The 2008 OEM rates are 284 (5.07 kg/mm) front and 299 (5.33 kg/mm) in the rear. This is not much different than the Modulo specs if this it is accurate.
Should I purchase the suspension or just stay stock? Suggestions?
Can anyone help pleaes?
Thanks
Specs are:
Thanks
