Sponsored by: Sake Bomb
Nervous steering?
Old 01-18-2014, 02:32 AM
limited976's Avatar
Default Nervous steering?
Hey,
I've got something going on I think. When driving my S2K it feels nervous?
I mean, when accelerating in a corner it pulls to the opposite steering direction.
On a straight end no problems what so ever.
The car has a KW Variant V1, was aligned. After the alignment I lowered the car in the front by 2 cm and the rear by 1 cm.
There was also a problem with the left wheel bearing and hub wich got replaced by new OEMS. After that, it was a lot beter,
but still not completely gone.
Front tires 225/40/18 , rear tires 225/40/18. Pressure 2.5 bar/kg.
Any suggestions? Rubbers? Where?
Compliance bushings?
Old 01-18-2014, 08:07 AM
s2000ellier's Avatar
if you changed the ride height you changed the alignment. have it aligned again
Old 01-18-2014, 11:32 PM
ssonsk's Avatar
^ ha yup
you answered your own question
Old 01-19-2014, 01:27 AM
limited976's Avatar
Best to order the powerflex bushings then I supose
Verstuurd vanaf mijn LG-D802 met Tapatalk
Old 01-19-2014, 07:22 AM
Fokker's Avatar
Replacing the bushings is not going to eliminate the need to realign the car if you alter the ride height.
Old 01-19-2014, 03:44 PM
Gottabfast's Avatar
Usually steering is nervous or twitchy due to toe (front or rear),bump steer, something loose/broken, or a tire issue. What does the steering wheel do if you hit bumps? If you lowered it more after you aligned it, have it realigned and toe reset.
Old 01-20-2014, 09:29 AM
limited976's Avatar
Tires 225/40/18 all round, I'm going to change the rear to 245/35/18 and Re-align it. When I hit speed bumps the wheel stays straight.
Mangineer
01-09-2014 03:08 PM
Floppy
07-25-2013 12:02 PM
kaansahbaz
12-24-2010 05:12 PM
superjimbo
02-24-2006 03:59 PM
Brutewes
08-24-2003 09:01 AM
Quick Reply: Nervous steering?
