New Ohlins DFV Road & Track Coilovers (HOS MI21)?
#121
Now I've tried my HOS MI21 on the track and they feel fantastic.
Have to make some adjustments to the rear shocks since the car feels a bit stiff in the rear and it almost felt like I loose grip when turning hard at high speeds.
I have them set on 15 clicks all around with the factory springs.
I can't really compare them to my KW V.3 since I've changed both the power output a lot, the rear brakes, aero and tire size and tirebrand since last season.
But even so, with the original factory springs the car feels and drives great.
SakeBomb Garage (06-20-2019)
#122
Appreciate all the positive comments on our kits in this thread! We do want to say we have a package already up on the website. You can get the kit with the 10kg/8kg springs here or upgrade to 12kg/10kg!
SakeBomb Garage Ohlins S2000 Package includes FPSpec Lowering forks and Remote Adjusters.
https://www.sakebombgarage.com/s2000...ote-adjusters/
Additional upgrade available for a higher performance spring rate at an additional cost.
KIT INCLUDES:
KIT INCLUDES:
- OHLINS MI21
- FPSPEC LOWERING FORKS
- FPSPEC REMOTE ADJUSTERS
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
#123
I always questioned my numbers because a number of these brandname coilovers comes out of the factory sitting on bumpstops pretty much... It appears i'm not crazy after all, lol... props to Ohlins for publicly including these kind of information and actually doing real r&d testing.
question is why did the original Ohlin designer set it up with only 5mm of travel in the rear before hitting bumpstop, that seems insane for an Ohlin product !
i guess they are shock body length limited with the way the bottom mounts are made.
anyways, does anyone have a shock dyno graph of these new shocks? I would love to see them to see what damping ratio they valved it for.
#124
Not only do our custom made cups allow you to preload as much as you need, they also allowed us to create a completely new variant called our FPSpec Long Stroke Ohlins (albeit, at a much higher price point)... but that additional room for shock body into the cup allowed us to fit a physically longer damper in there!
Lowering Cups ("Low Profile Forks") -> https://www.sakebombgarage.com/fpspe...ng-fork-s2000/
Accessory Pack + MI21 (optional tuned spring rates) -> https://www.sakebombgarage.com/s2000...ote-adjusters/
FPSpec Long-Stroke DFV's - Custom made -> https://www.sakebombgarage.com/fpspe...ins-dfv-s2000/
The Ohlins hardware itself is phenomenal... if we felt Moton, AST, etc had better hardware we'd build our custom kits around those components. It just so happens that we feel Ohlins has the leading edge in suspension technology, and our SCCA/NASA and other world race series wins prove that. Ohlins will succeed or fail based on their setup (so would any suspension) and the magic is in the valving, rates, setup etc... this is where S2000 suspension experts like ourselves come in. Our background is in motorsports chassis dynamics, and we've been able to fine tune the standard Ohlins kits with custom accessories, cups, spring rate options... and then max out the DFV's themselves from a hardware sense with our custom valved bespoke FPSpec Long Stroke versions, floating top hats, custom valving with improved race-grade shock oil etc.
If you have any questions about standard or bespoke Ohlins DFV kits, please feel free to email us: Info@SakeBombGarage.com
Cheers!
SBG
__________________
#125
I purchased the MI21 kit shortly after they were released with the 11KG/7KG spring rate. Contacted Sakebomb and per their recommendations and what i was going to do with the car I went ahead and upgraded the rear spring to 9KG along with adding the Rear lowering forks, and Remote adjusters. Thanks to them car feels and reacts perfect to my taste.
SakeBomb Garage (06-26-2019)
#126
__________________
jasserv (07-24-2019)
#127
I have the FP Spec Longstroke Ohlins and they are absolutely amazing. I personally think they're worth the upcharge over regular Ohlins and are probably my favorite thing on the car at this point.
SakeBomb Garage (06-28-2019)
#128
We appreciate this! You're a champion!
__________________
