Noises
check your rubber bushings and try spraying silicone lubricant to see if that cures the squeaks...mine was a creak sound that resembled somewhat of an old spring mattress and it turned out to be a torn cv boot, hope that helps gl.
see if you can pinpoint the area and see where the squeak comes from and jack up the car and remove the wheel and spray all rubber bushings in that area (control arm, swaybar, etc.) especially if the bushings appear dry with a silicone lubricant. liquid wrench makes a silicone spray and I'm sure there are a few others, gl.
Moddiction
Mar 23, 2011 07:12 AM
