Sponsored by: Sake Bomb
Rear Toe Arm Bolt Size
Old Aug 2, 2021 | 01:54 PM
DailyDrivenLBP's Avatar
Default Rear Toe Arm Bolt Size
I'm in the process of replacing my OEM rear toe arms with Hardrace adjustable ones. The bolts that you would use to adjust the toe from the factory were rusted solid to the OEM arms so I had to cut them out. I can't find replacement ones anywhere online so I'm going to try a hardware store but I need the exact specs of the bolts (which I also have been unable to find). The car is a MY 2006. Also, if anyone has an easier solution let me know!
Old Aug 2, 2021 | 03:15 PM
B serious's Avatar
belmetric has an excellent selection of JIS bolts.
Some hardware stores carry JIS...but the selection is wack.
If I remember, I'll measure the length of the stock bolts I may have laying about. IIRC, its 80mm.
Its M12x1.25.
JIS reduced head flange
Bolt and nut
Class 10.9 (extremely important)
The OEM nut is a nylon locking type.
You don't need the stock cam bolt since you have adjustable arms. But if you wanted to use the stock bolts/nuts/cams....stock ones can be found on any Honda parts site or a lot of times on eBay.
Fergal
Oct 18, 2017 09:43 AM
2004TurboS
Apr 4, 2014 01:36 PM
KUpton83
Mar 21, 2014 08:57 AM
r8byb
Jul 29, 2010 01:35 AM
