Sponsored by: Sake Bomb
Slammed, and functional?
Old Nov 7, 2012 | 07:29 PM
Back S2k's Avatar
start from part 1 and read through all the parts even the drifting set ups.
http://www.motoiq.com/tech/the_ultim...apg-448/2.aspx
ur welcome
Old Nov 7, 2012 | 07:42 PM
Carbon Blue's Avatar
Originally Posted by dc2-2-ap1
Slamming it makes it handle like crap because it practically eliminates suspension travel, and severly changes the suspension geometry. This car was designed to be the height that it came from the factory, a little drop may help, around 1", but 3" completely changes the way the suspension functions. If they were to redesign the upper and lower a arms, then they could potentially utilize that drop and have it not hinder performance.
Using cheap coilovers, regardless of ride height, also hinders handling. Sorry, but godspeed, d2, stance, ect are not quality. That is equivalent to taking all season touring tires to the drag strip. Technically they are tires, but not designed to be used in that way. Using quality coilovers, and dropping them lower than their efficiency range, essentially turns them to overpriced crap.
And about the tire situation- yes, a little stretch does help prevent sidewall flex and helps maximize tread patch. Putting a 245 on a 9" wheel is a good example of this. Stretching a 225 on a 10" wheel is not. It puts stress on the sidewall in ways it was not designed to, and decreases contact efficiency. Tires are designed to fit on specific size rims based on tread width. A 5'6" man weighing 400 lbs wouldn't go outside trying to fit in a 28" waist pair of pants- why would you expect your car to do something similar.
this man deserves a trophy. The amount of craptastic coilovers out there amazes me, but what amazes me even more is that people still continue to purchase them..
Old Nov 7, 2012 | 08:21 PM
profit_child's Avatar
i belive i have good function and form... you can have the look you want and the performance you want... if done properly...
current set up 245 x4 17x9.5 work xd9s
tien circuit master RA's 2.5 inch drop all around
toe arms in the rear...
im one of the guys that went from hella flush (rice) to functional (nice)
teaser below of what i would say slammed functional
Old Nov 7, 2012 | 11:08 PM
pboi's Avatar
This is the height I track mine at. Just started tracking, comparing laptimes with other s2000's, I believe its still very functional
Lowered on Tein SRC.
Old Nov 8, 2012 | 09:04 AM
Dreaming_S2k's Avatar
I came in here ready to type a long post but....basically this
Old Nov 8, 2012 | 11:01 AM
4forall's Avatar
It basically boils down to geometry and the suspensions ability to keep as much tire on the ground through changes in direction and elevation.
When you slam the car you are reducing the ammount of room the suspension has to do its job. When you buy a cheaper coilover system that is
not able to do the job very well to begin with, and then give it a shorter distance to do the same job it just cannot keep the tire planted.
More expensive sets not only lower the car for looks/center of gravity but have the compression and rebound dampening ability to do the job as well as eliminating excessive body roll.
In most cases the stock suspension does a much better job at doing this because thats what it was designed to do.
This is just a very small part of what goes into it. But will give you a basic idea of why cheaper systems are not recomeneded for track use.
Old Nov 8, 2012 | 01:36 PM
jaor.s2k's Avatar
^^this guy
favorite lowered and tracked s2000 on the forum, and favorite s2000 overall lol
Old Nov 8, 2012 | 07:22 PM
sheel's Avatar
Chuuuurch!
The stock suspension is actually very good. High quality, monotube construction... people ruin their cars handling by throwing on crap products with inferior design.
Old Nov 8, 2012 | 07:54 PM
AP2CRazy's Avatar
Quoted for the truth . Leave the hellaflush to the toilet please
Old Nov 9, 2012 | 08:56 AM
B3AS's Avatar
dropping it 3 inches hurts the roll center, and geometry as said above. About the only cars u will see riding around with good suspenion and slammed are the 240sx guys. they have tons of aftermarket support for suspenion, including some nice drop knuckle options.
as long as u keep the camber within reason, your car will be fine for street driving.
