View Poll Results: Which would you choose for a track day car?
Voters: 85. You may not vote on this poll
Track orientated coilovers
I am new to the S2000, owning it for about 7 months but it has only been in my possession for about 2 weeks. I frequent the Nurburgring and will travel around Europe to different open track days. I am not at all concerned with comfort. Any help is greatly appreciated, thank you.
Also, just because you have that much to spend, theoretically, it does not mean you should. I don't think such a young owner of the car should jump right into $3500 shocks, when koni yellows will do the job. Also, the better the shock, generally the more comfortable, not the opposite.
Ohlins! =)
You should also check out HKS that Evasive Motorsport sells which I believe is good enough for your intentions re: open lapping and tracking. It sells for about $1800. I think you should start with coils that aren't the most expensive ones. If you think that they're not good enough for you then you can upgrade to the high end stuff later on.
There is a thread on the HKS where reviews were done which you might find helpful. Good luck!
