Sponsored by: Sake Bomb
Urge/Ohlins TTX36 Initial Thoughts...
Old Mar 15, 2015 | 06:12 AM
eddie8181's Avatar
Default Urge/Ohlins TTX36 Initial Thoughts...
From the start I knew I should be looking at suspension to be more successful on the track. When I finally took the plunge late in 2014, the result was not surprising. It was trans-formative. Although I haven’t had much track time to fine tune, with the help of Patrick (and some dumb luck?) the initial results have exceeded my expectations.
’08 CR
Ohlins TTX/12k, 10k/all the bits and pieces/double adj. /Lowered about 1”
Hoosier 235/620x17 on CE28x9’s
Carbotech pads-10’s and 8’s
Adj front sway at 566#
-3 camber /0 toe; -3 camber/1/16 total toe in-rear
Installation was straightforward. After having the car corner balanced and aligned, I found it negotiated crappy Ohio roads much more comfortably than stock. Starting the adjusters both mid range, at Mid Ohio, lap times were reduced 4% out of the box and the car was very steerable with the throttle. Before an electrical issue at Daytona, I saw 144 in practice and the car was completely controllable in the tri-oval. Not using all the travel, yet, so looking to soften the settings this spring. Shoulda done this a long time ago. Still one of, if not the biggest bang for the buck…with a big tip of the hat to Patrick at Urge who is always incredibly responsive, responsible, and interested.
Old Mar 16, 2015 | 07:27 AM
thomsbrain's Avatar
I'm jelly. The TTX have a level of low-speed control and low stiction that the DFV can't seem to match.
Surprised you're still on those Carbotech 10/8's on slicks!
Old Apr 18, 2015 | 01:28 PM
Urge's Avatar
Sponsor
4% reduction in lap times!!! HUGE.
That is a lot of value. Only a Supercharger or Stroker short block at around the same cost can reduce lap times by 4%.
__________________
Old Apr 21, 2015 | 11:54 AM
bgoetz's Avatar
What were your times at mid-ohio after tossing on the shocks and what power mods do you have?
integfoo
Jun 6, 2015 06:15 PM
02_s2k
Apr 22, 2013 03:48 AM
Biohazard
Oct 19, 2012 08:05 AM
dorikin_86
May 31, 2007 11:14 AM
ZDan
May 7, 2007 08:44 AM
