Sponsored by: Sake Bomb
VSA Light on
Old Feb 3, 2014 | 08:56 AM
atee12's Avatar
Default VSA Light on
My 2006 S2k has its VSA warning light on. This appeared after a short lay up and after I charged the battery which tough not flat needed a lift to start the car . The car is standard, no mods. The VSA switch has no effect. The dealer says it the pressure module(?) that can only be replaced by replacing the brake control module for a whopping £1800. Can this problem be rectified more simply ( and cheaper) than this? The car runs normally no other problems.
Old Feb 3, 2014 | 02:39 PM
RedCelica's Avatar
have you checked the float in the brake master cylinder?
https://www.s2ki.com/s2000/topic/668...trol-light-on/
https://www.s2ki.com/s2000/topic/940...ight-stuck-on/
Old Feb 5, 2014 | 07:17 AM
Gottabfast's Avatar
What code was stored? If it's the pressure sensor (usually code 66-xx) it's internal to the modulator and isn't serviceable. If it's code 68 (brake switch input) or 65 (brake fluid level) there's hope that the modulator isn't the issue. There is a code 61 for low battery voltage, but that should clear easily once the voltage is back up.
Old Feb 7, 2014 | 09:22 AM
kgiannis-rodos's Avatar
I have the same problem in my S2000....
VSA is always light on and from honda dealer tell me to change the system ABS?...
Please help if someone know some better what to do....
Old Feb 7, 2014 | 09:42 AM
I have the same problem with s2000 vsa '07.
The vsa light on is always ON.
I take the car in dealer honda and we see a error (usually code 66-xx).
They tell me to change all ABS system???but the cost is very expensive.
Please if you can tell me some more information and help me send me message .
Frienldy john
Old Feb 7, 2014 | 09:44 AM
Frienldy john
xrapidx
May 21, 2024 04:34 PM
nichigo
May 8, 2019 03:55 PM
s7paul
Nov 5, 2018 02:25 PM
Dflwrx
Aug 7, 2017 11:41 AM
Lloyd Six
Feb 22, 2006 11:53 AM
