What way to go.....
What way to go.....
Just looking for some advice on which way to go....
Have tein 20mm lowering springs but burst a damper the other day and am wondering if its best to change the complete set up....
The damper im not to confident on so thas why im wondring on which is the best way to go...
that would really depend on you and your budget/situation, purpose of the car?
how long have you had the tein springs with stock shocks? if you like the ride and have no problem with it, no problem just changing the shock and be on your way
there is always upgrading your shocks which is recommend or just switch to complete coilovers, kind of hard for anyone to help without knowing more info
The car is/will be a daily driver....
As for the budget im not so sure about.....Had the springs in a couple of weeks and was happy enough....
I went with springs due to the fact that i put 17's on and the car looked like a 4x4 when it was done..So rolled the arches and got it to sit a bit lower....Was toying with the idea at the time of changing the whole suspension...
Since the damper went im now getting very councious of every bang that i hear coming front the front drivers side....
Im sure that if changed all the dampers that this would then sub due....
Is it possible to just get Tein dampers and put my spring son and work away...???
