<>*<>Apexi VAFC controller<>*<>
Old May 17, 2004 | 09:02 PM
s2khondaimport's Avatar
Default <>*<>Apexi VAFC controller<>*<>
just wondering where is the best place to mount?
also, at what rpm should the vtec engagement be set at? (4500 rpm, is it ok?)
thanks
Old May 17, 2004 | 10:04 PM
NFRs2000NYC's Avatar
As for the VTEC point..post it up in the UNDER THE HOOD section.....
(4500 is way to low)
As for the mounting, I would do it either in the radio door, or in the space BEHIND the cupholder.
Old May 18, 2004 | 08:20 PM
S2K1's Avatar
I'd put the VTEC at 5500-5800RPM.
Old May 19, 2004 | 08:18 AM
i thought the stock rpm for vtec is 5800???
is it a big difference if i lower it to 5500
Old May 19, 2004 | 01:46 PM
S2K1's Avatar
On '00-'03 it is roughly 6000-6200 RPM at stock, to make it really smooth and gain power, you don't want to lower it much. If you do lower it to 5500, it is a very big difference in feel. You will no longer feel the VTEC 'kick', which disappoints some, but you will have a smooth transition and gain power in that range. I gained almost 10WHP with my V-AFC II.
Old May 19, 2004 | 07:27 PM
thanks s2k1, did you have to keep tuning and retuning yours, bc i heard it is just not "plug and play"
also, if i decide to not use the vafc anymore, will the vtec go back to normal(stock), like back to 6000?
will the car be normal again? (like i never installed the vafc II ever).
thanks
Old May 19, 2004 | 08:28 PM
S2K1's Avatar
I only had mine on for about two weeks and drove the car a total of 200 or so miles with the V-AFC. After that I took the V-AFC out(which returned it back to normal) and I went turbo with a Greddy E-manage.
fishs2000
Aug 30, 2008 05:45 PM
s2khondaimport
May 18, 2004 11:29 AM
QCK HNDA
Nov 1, 2001 04:47 PM
uhear
Oct 17, 2001 03:43 PM
bobatimez
Apr 5, 2001 05:28 AM
