08 keyless control unit schematic
Old Nov 11, 2014 | 07:43 AM
s1mba's Avatar
Default 08 keyless control unit schematic
Does anyone have the schematic/diagram? Alarm is wired up and everything is done but when we press the trunk switch in the glovebox we get an electrical buzz. Trying to diagnose the issue.
Old Nov 11, 2014 | 08:00 AM
oth's Avatar
oth
The black/yellow wire from the keyless joins up with the black/yellow from the switch,
which in turn connects through a connector to the blue/light green wire of the trunk
latch, supplying +12v to energize the solenoid to release the trunk
Old Nov 11, 2014 | 08:23 AM
s1mba's Avatar
Thanks. Still trying to figure out why this relay keeps buzzing when the truck switch is pressed. Trunk opens perfectly fine without any noise with the alarm key fob.
Old Nov 11, 2014 | 08:45 AM
not4s4l3's Avatar
Also this might come in handy later..
https://www.s2ki.com/s2000/topic/109...#entry23263828
Old Nov 11, 2014 | 09:15 AM
oth's Avatar
oth
If you haven't already, I'd check the voltage at the connector in the trunk and see
if it's any different pressing the button vs. the fob.
You may also want to check fuse #26 - it supplies the power for the switch but not
the keyless.
EDIT: took too quick a look - #26 does supply the keyless too, so never mind that.
Old Nov 11, 2014 | 10:26 AM
s1mba's Avatar
We ended up using a PAC TR-7 module as a bypass which sort of did the trick. I have to hold the trunk switch for about 3 seconds to get it to work but no more buzzing!
stillmelloq
Jun 29, 2008 05:10 PM
nazaracing
Mar 29, 2008 09:15 PM
SandyS2K
Apr 24, 2004 10:14 AM
SandyS2K
Apr 22, 2004 05:03 AM
