trunk release button
Old Jun 22, 2008 | 12:44 PM
stillmelloq's Avatar
Default trunk release button
i just discovered yesterday. i tried opening the trunk by using the trunk release button in the car. and it was working. im just wondering what could be the problem? is the button electronic or is it a latch. because a month ago, i got an alarm installed in my car. and maybe my installer missed something. its an 2008 by the way. thanks for looking
Old Jun 22, 2008 | 03:08 PM
darkknight1999's Avatar
It has an electric release. Did your installer give you a new remote that is also programmed to pop your trunk? Did you check the fuse?
Old Jun 22, 2008 | 05:23 PM
i use the remote that came with the alarm. I didnt check the fuse yet. where is the fuse for that? sorry for the newbie question
Old Jun 22, 2008 | 05:29 PM
Should be under the drivers side dash... I forget the number fuse it is sorry. Try your stock remote and see if that works.
Old Jun 28, 2008 | 02:21 PM
gumbey75's Avatar
if your able to open it from the inside, and not with the remote, pretty sure he didnt wire the trunk pop feature on the alarm.. if its a negative wire its a straight hook up, if its a + you have to hook up a relay to get it to work..
Old Jun 29, 2008 | 05:10 PM
Luckyaze's Avatar
Definitely electronic, when I took out my battery the button/or the remote won't work and had to be open manually from outside.
HarryD
Oct 28, 2018 03:15 PM
Kane_X3
Aug 16, 2008 08:52 AM
iluvs2ks
Jun 13, 2007 08:51 AM
Saki GT
May 30, 2007 09:20 PM
Bass
Aug 21, 2003 09:16 AM
