12" Eclipse titanium and Trunk rattle
Old Apr 12, 2003 | 03:04 AM
allenheathdj's Avatar
Default 12" Eclipse titanium and Trunk rattle
I have a 12" Ecllipse titanium in a fibertglass molded box in my trunk powered by a 1000 watt Helix amp and my trunk is rattling excessively. I could see the trunk lid actually move when the bass is hitting hard plus when i push the trunk down 95% of the rattle goes away, what should i do to make the rattle stop because it its resonating back into the cabin and its making my car sound like a 88 sentra with swapmeet speakers in it.
Old Apr 12, 2003 | 03:20 AM
lucid's Avatar
well 1000w to a 12" sub will do that! Take all the lining out and dampen everything.
Old Apr 12, 2003 | 10:06 AM
TepEvan's Avatar
yea, what do you expect?
Old Apr 12, 2003 | 01:55 PM
RS2000's Avatar
Have you deadened your trunk yet? If you have, consider adding more layers.
Old Apr 12, 2003 | 02:57 PM
brerspidur's Avatar
similar set up here ( diamond M6 titanium , memphis 1000D) similar problem,, . .my solution, lots of dynmat, and put the top down, 95 percent of my rattles go away with the top down.
Old Apr 13, 2003 | 02:33 AM
Thanks alot for the advice i am going to put 2 layers of dynamat in the entire trunk area and see what difference it makes.
Old Apr 13, 2003 | 11:59 AM
Partshelper's Avatar
use the spray dampening system first.. from like dynamat, or lightning audio, then dynamat it and it works good. i did that and it took away the rattle..
Old Apr 13, 2003 | 02:24 PM
lucid's Avatar
You know what rattles you get too? Hardtop rattles. I'd like to see a creative way of fixing this
Aren
Jun 14, 2007 03:43 PM
nEVERCLEAR
Aug 30, 2002 12:50 PM
jays2000
May 15, 2002 04:59 AM
jws626
Apr 13, 2001 05:04 PM
