12V Power for Gauges
Old May 5, 2008 | 07:08 AM
scott2055's Avatar
Default 12V Power for Gauges
I'm trying to wire the light for my boost gauge to come on with the headlights. I've searched several times and all of the threads I've come across have dead links or missing pictures. I found the install instructions for MacGuyvers windscreen lights and I think I found where I can wire up the gauges but I wanted to check just to be safe.
The installation instructions contained the following picture:
Would I just wire the power for the gauge light into the top slot (labeled "E - Lights")?
I've also read up on the under dash fusebox on the driver's side and it appears that a "blue wire" runs the parking lights. (found here) Is this accurate? Would it be easier (or safer) to just go directly into the fusebox rather than the wire?
Thanks!
Old May 5, 2008 | 07:42 AM
oth's Avatar
oth
yes, that picture shows the extra accessory terminals in the fuse box, and
the one labeled "lights" is the one that is powered when the lights are on
(BATT = constant 12v and IGN is switched with the ignition switch/key).
This is the best way to hook up something rather than splicing into a different
wire. Probably best to use an inline fuse in the wire leading to your gauge
lights, assuming there isn't one there already.
Old May 5, 2008 | 08:35 AM
rwheelz's Avatar
Is it possible to wire aftermarket gauges to the rheostat for the dash? So we can dim the aftermarket gauges slightly as well?
Old May 5, 2008 | 09:16 AM
scott2055's Avatar
thanks for the quick reply!
archtop
Apr 25, 2009 11:44 AM
flexer
Feb 1, 2009 07:10 AM
fadiss2k
Mar 5, 2006 02:33 PM
wortham
Jan 24, 2004 11:12 AM
