Autometer Gauge Lights Wired Into Dash Lights?
Old Apr 19, 2009 | 01:17 PM
archtop's Avatar
Default Autometer Gauge Lights Wired Into Dash Lights?
Can I wire my Autometer (2) gauge lights( incandescent not LED) into my dash lights so they dim with the dash cluster? I'm using the lights power extra spade terminal on the interior fuse panel and the gauge lights come on with the headlight light switch but do not dim with the gauge lights.If so which fuse do I tap into.I have an 06'.
Old Apr 24, 2009 | 05:17 PM
imdarkrider's Avatar
yes, you need to hook it up to the dimer, there's not a set fuse you can tap into as those read 12v all the time. The way a dimmer works is with a potentiometer, which adjusts voltage going to the lights making them brighter or dimmer. Either get a potentiometer to adjust your lights, or tie them into the dimmer.
Old Apr 25, 2009 | 03:22 AM
archtop's Avatar
Thanks,I found out that you can wire into the dimmer by using the re/blk wire for the hot (white wire) of the guage lights and the red wire of the cruise dash light for the return (or black wire) of the light off the cruise control on/off button on the dash.Only drag is you have to drop the steering wheel column and pull off the dash trim to get to it.There must be an easier way?
Old Apr 25, 2009 | 05:06 AM
technically there is, you can catch the dimmer wire behind the radio since the radio dims with the cluster as well.
Old Apr 25, 2009 | 06:18 AM
archtop's Avatar
My gauges are on the A pillar.Is there anything near the fuse panel under the dash I can tap into. Thanks John
Old Apr 25, 2009 | 11:44 AM
no sorry, the potentiometer is high up in the cluster making it about as easy to get to as it is the actual switch behind the cluster. It's easy to pull the radio though and just run a wire.
Forgottens2k
Jan 17, 2016 03:14 PM
dak24
Mar 12, 2015 06:44 PM
billiardboy904
Jul 30, 2010 04:40 AM
hornyhonda
Jul 21, 2007 08:04 PM
bronzed
Sep 20, 2004 08:58 PM
