Audio gurus...Need your help
Old Oct 17, 2011 | 10:49 AM
FearlessFife's Avatar
Default Audio gurus...Need your help
Hey guys.
I recently acquired an Eclipse CD4000, and everything is working great...EXCEPT the pre-outs. This particular receiver has three sets of them, and via a voltage meter check, they are not pushing a signal at all. So my amp has power, but is not getting a signal from the receiver for sound...so the sub is not working.
I've searched the internet and through the owners manual, and I can not find a solution to the problem.
Thoughts or ideas on what this could be?
Old Oct 17, 2011 | 12:06 PM
iDashX's Avatar
Some headunits require you to turn them on. These by default are not always on due to possible interference and can cause a short. (E.g. some older clarion head units )
Sent from my MB860 using Tapatalk
Old Oct 17, 2011 | 12:11 PM
That's what I was thinking.
I have searched all over the internet and looked through the manual at great length for how to turn them on, but no luck thus far.
Old Oct 17, 2011 | 03:31 PM
gumbey75's Avatar
eclipse do not have a feature to turn off pre-outs, My Cd8455 never had such problems and as far as I know never had a feature that I seen where it was able3 to turn off. the Eclipse I have is for sale if interested(not to thread jack)
Old Oct 17, 2011 | 06:38 PM
oth's Avatar
oth
Is the headunit producing sound through the speaker outputs, just not
through the RCA (preamp) outputs?
A few things to confirm -
- volume knob is not turned all the way down
- output is not muted
- you are measuring AC voltage, not DC, in the proper range (fraction of a volt
to a few volts)
Old Oct 27, 2011 | 12:40 PM
to a few volts)
Speakers up front definitely have sound.
Output is not muted.
And we did measure AC voltage.
Old Oct 27, 2011 | 12:50 PM
TPhong's Avatar
I say try a different set of RCA's, just so you can eliminate that as a problem. Are you sure that the RCA inputs on the amp aren't bad?
dammitjim
Jul 30, 2010 09:23 AM
AZDavid
Aug 15, 2008 05:02 PM
Drakul
Aug 13, 2008 03:16 PM
jeffbrig
Feb 16, 2007 08:36 AM
nambiker
Jan 8, 2007 07:10 AM
