4 Ohms?
Old Jul 16, 2003 | 05:44 AM
Ajjra's Avatar
Default 4 Ohms?
When I install a new system, I will want to run at 4 Ohms and not 2 Ohms, right? This would produce better sound quality?
Old Jul 16, 2003 | 07:00 AM
smyroad's Avatar
That depends on the head unit/amp power and impedance rating along with the speaker configuration, power rating and impedance. For starters, you want everything to match.
Old Jul 16, 2003 | 07:24 AM
PJK3's Avatar
this will depend on the both the speakers and the amplifier(s) you choose.
for front speakers, you probably won't have a great deal of choice on whether you run 4 ohms or 2 ohms. typically, front speakersa are more limited on how you can configure them w/o running into fader and/or balance issues. and most components come configured for 4 ohm loads. if you're considering the Kicker RS6c, those are 4 ohm components.
for the sub, you'll need to consider whether the amp is stable at 2 ohms in a mono configuration (which i do not belive the Kicker 800.4 is). if you use an amp that is stable at 2 ohms mono, you need to be aware of the power handling abilities of your sub(s). otherwise, you'll need to plan to run a 4 ohm sub load.
outside of stability and thermal issues - there should really be no discernable sound quality difference between a 2 ohm or 4 ohm setup. it's mainly an issue of power.
Old Jul 16, 2003 | 08:05 AM
mgiang7's Avatar
[QUOTE]Originally posted by PJK3
[B
Old Jul 16, 2003 | 08:21 AM
PJK3's Avatar
really!? i wonder how you might know that??
mmm... i bet it gets toasty!
Old Jul 18, 2003 | 08:57 AM
Ajjra's Avatar
I think I have this figured out. The Kicker 800.4 will do 4 Ohms Stereo, unless you want to mix stereo and bridged, the you can only run 2 Ohms stereo while the other 2 channels are bridged for your sub.
Old Jul 18, 2003 | 10:06 AM
PJK3's Avatar
[QUOTE]Originally posted by Ajjra
[B]I think I have this figured out.
Old Jul 18, 2003 | 10:15 AM
TepEvan's Avatar
[B]really!?
Old Jul 18, 2003 | 12:00 PM
PJK3's Avatar
[QUOTE]Originally posted by TepEvan
[B]
It's true.
s2krazy01
Jul 11, 2007 09:44 PM
kw2000
Jan 15, 2005 07:03 PM
VanceLancaster
Jul 12, 2004 10:54 PM
2000celicaspeed
Jul 8, 2004 07:24 AM
Jay2000
Aug 9, 2002 09:04 AM
