6 1/2" Sub Enclosure Help
Old Nov 27, 2007 | 09:09 PM
ft2057's Avatar
Default 6 1/2" Sub Enclosure Help
I'm looking for optimal dimensions for this 6 1/2" sub I'm thinking about installing in the secret compartment.
http://www.tb-speaker.com/detail/1230_04/w6-1139si.htm
The only problem is that the manufacturer doesn't provide the specs needed to build an optimal box for the speaker. I was wondering if someone can decipher the information provided in the given website and enlighten me with rough estimates of how much optimal airspace is required and the dimensions needed to meet those requirements.
Any help would be appreciated.
Old Nov 28, 2007 | 12:35 PM
oth's Avatar
oth
http://www.bcae1.com/
has great info including box calculators
Old Nov 28, 2007 | 02:36 PM
Cubs2k's Avatar
I've done lots of reseach on this driver......all the parameters you ever need are there.....
this driver works best in a vented enclosure....
you need .4 cu/ft
you need 2, 1 inch ports, 6.24 inches long to tune it at 38 hz
if you have room to go .5 cu/ft...you'll get a small boost around 45 hz
You can go sealed...0.2 cu/ft ..but you will be half as loud as ported at 70hz and far worse the lower you go.
I really like these little subs.....and they can take a lot more power than they are rated for.
dimensions are up to you.......
I used this driver's little brother to make a stealth sub for my passat
Old Nov 28, 2007 | 04:16 PM
ft2057's Avatar
Awesome! Thats exactly what I need! I do still have more questions though,to my understanding as long as I have .4 cu/ft and 2 1 inch ports 6 inches long I would get optimal preformance. The question is are there any good ways to do this with the secret compartment? I'm afraid it may look tacky.
Old Nov 28, 2007 | 05:08 PM
Cubs2k's Avatar
I personally wouldn't use it there...passenger foot well would be more likely unless you are in high quality fabricating.
Old Nov 28, 2007 | 05:57 PM
ft2057's Avatar
I can learn high quality fabricating.
...I think...
Old Nov 29, 2007 | 09:56 AM
Sobe_Death's Avatar
Hey I know this sub! I have one in a 0.35 cu ft. vented enclosure in my Civic. You will NOT be disappointed with it's performance.
You might try using WinISD to figure out your box calculations. There are a bunch of pre-loaded driver specs in there including this one.
Old Nov 29, 2007 | 11:50 AM
Cubs2k's Avatar
Thats what I used for my earlier post.
BlackStar602
Sep 8, 2008 09:00 AM
JL77
Jan 11, 2006 03:31 PM
NFRs2000NYC
Jun 19, 2003 01:02 PM
Blue Bitch 2K
Apr 6, 2003 07:42 PM
Jaysom
Apr 4, 2002 05:03 AM
