Adding rear usb port to headunit
Old Nov 10, 2011 | 09:30 PM
S2K.Danny's Avatar
Default Adding rear usb port to headunit
My headunit, a Sony CDX-GT630UI, has a USB port on the detachable face, but not on the rear.
I got tired of being forced to keep the radio door open all the time while driving as I keep my iPhone plugged in & use it for music 99% of the time.
So I have it all torn apart, and am going to be soldering a female usb cable directly to the pcb and have it sticking out the back!
Now, if I can find my *$#%ing dmm I can start soldering =)
I'll post up pics when it's done!
Old Nov 10, 2011 | 11:53 PM
aphex4000's Avatar
like where this is going!
Old Nov 11, 2011 | 01:26 AM
cvjoint's Avatar
Could you have used a bent neck usb instead? You can then run the wire under the panel and have it come out under the radio door.
Old Nov 11, 2011 | 05:42 PM
S2K.Danny's Avatar
That is the route I was forced to take..
The Data +/- for the usb port did not trace back from the front flip-down face plate to the pcb inside the headunit. The usb connection on the faceplate is decoded into a chip that's on the faceplate's pcb. So no access to the usb data pins from inside the headunit, only the faceplate.
So I took apart an old usb cable & used just the metal end male plug piece & soldered a female extension onto it, wrapped it in electrical tape & called it good.
I'll get some pictures up when I get a chance..
Now I'm working on getting 6x8's in the doors. Although they fit most 5x7 locations so technically it's a 5x7 I suppose?
These are what are going in there.
aphex4000
Mar 6, 2013 07:19 AM
S2000Matt
May 25, 2012 05:54 AM
starrman
May 24, 2011 12:43 PM
HKStallion
Jun 28, 2009 06:56 AM
Sunchild
Dec 28, 2000 12:44 PM
