AEM EMS and Temperature gauge
Old Nov 28, 2004 | 04:57 PM
  #121
modifry's Avatar
Honorary Member
[QUOTE=cbender,Nov 24 2004, 11:25 AM]Heh, Modifry, here's an odd question for you, but is there any way that I can use the device to drive a temperature display for my OIL temperatures (I currently use one of the AEM EMS EGT inputs to monitor my oil temps using a sensor mounted in my oil pan)?
Old Nov 28, 2004 | 04:58 PM
  #122
modifry's Avatar
Honorary Member
Originally Posted by jcarlton,Nov 25 2004, 04:23 PM
When and how much?
Damn good question. How about $75 and before Christmas?
Old Nov 28, 2004 | 06:10 PM
  #123
AusS2000's Avatar
Sounds good!
Old Nov 28, 2004 | 06:19 PM
  #124
honda9krpm's Avatar
Originally Posted by modifry,Nov 29 2004, 11:27 AM
In it's current configuration the module will accept an input from any sensor that provides a 0-1v DC signal. I'm using 1v because that's where the stock sensor is when the temperatures become meaningful and because that gives me (hopefully) resolution to .001volts.
how quick does this unit response modifry?
do you think it can be hooked to a wideband 0-1V output?
Old Nov 28, 2004 | 06:25 PM
  #125
AusS2000's Avatar
Perhaps Stage 2 should be a preprocessor that looks at several inputs and can display different ones at the press of a button. And with alarm limits so that if one signal goes beyond a threshold it jumps to the front and emits an alarm.
But as I say, Stage 2...
Old Nov 29, 2004 | 12:38 PM
  #126
modifry's Avatar
Honorary Member
The factory ECT gauge has a 10-second delay per segment, so I don't think this would be a good application.
Old Nov 30, 2004 | 07:26 AM
  #127
cbender's Avatar
[QUOTE=modifry,Nov 28 2004, 08:57 PM] In it's current configuration the module will accept an input from any sensor that provides a 0-1v DC signal.
Old Nov 30, 2004 | 11:21 AM
  #128
Reefwalker's Avatar
[QUOTE=modifry,Nov 16 2004, 08:10 AM]I will do some testing on '04 cars after I'm done with the module for earlier years.
Old Dec 7, 2004 | 08:41 AM
  #129
yakrat's Avatar
Any updates?
Old Dec 20, 2004 | 03:55 AM
  #130
AusS2000's Avatar
