alarm back up battery
Old Oct 2, 2013 | 11:31 AM
sn0wman's Avatar
Default alarm back up battery
hey guys. i got a clifford g4 installed recently and the installer put the back up battery in the engine bay. i want to move it somewhere else so it looks cleaner.. any ideas?
here is how it looks like:
Old Oct 5, 2013 | 04:27 PM
BLAQ&GREYs2k's Avatar
Id splice on some longer leads and put it under the dash inside the car.
Old Oct 6, 2013 | 05:39 AM
tsuyoshi's Avatar
There are some "stealth" install options to hide the entire unit that an experienced installer should be able to point out for you. More hassel so install may cost more but makes it harder to get at.
Old Oct 6, 2013 | 09:21 PM
sn0wman's Avatar
thanks for the replies guys. im going to ask the guy who installed it. the idea to put it under the dash sounds good
Old Oct 19, 2013 | 01:04 PM
wisdom's Avatar
That looks like a siren and not a backup battery.
Old Nov 12, 2013 | 01:14 PM
modifry's Avatar
Honorary Member
It's a stealth backup battery, looks like a siren to fool the bad guys.
Locations for battery:
  • Behind one of the front fender liners, near the firewall. There is lots of room in there but it's protected from engine bay heat and the weather.
  • If you feel like running long wires, on the left side of the gas tank.
  • Behind one of the side carpeted panels in the trunk.
  • Depending on battery size, behind the passenger side foot well cover. There is a big foam block that fills the hole that leads into a cavity just in front of the passenger door. This is where the wires go through the door to the speaker and window switches but there is a good bit of room in there. This is a separate cavity from the one accessible under the wheel well.
  • Under the passenger's foot rest there is a large foam block, maybe cut a cavity in the foam to hold the battery.
  • There is also some room behind the access panels that are behind each seat.
Old Jan 4, 2014 | 09:02 PM
sn0wman's Avatar
you are the man Bob, thank you.
Bully9
Sep 6, 2015 11:56 PM
hughs2
Nov 26, 2013 07:50 AM
LEEF
Mar 22, 2013 08:52 AM
foxy
Dec 5, 2009 08:27 AM
BB_S2K
Mar 21, 2006 02:33 PM
