Alarm Installation Guide
Old Apr 11, 2007 | 10:03 PM
B.Money's Avatar
Default Alarm Installation Guide
Hey guys, well best buy installed my alarm but im not 100% pleased with everything they did..needless to say.. and its having problems with the prox. sensors.... so i want to learn how to do it myself...does anyone know of a good guide for noobs for alarm installation?
Old Apr 11, 2007 | 10:17 PM
Manny2587's Avatar
DEI alarms come with pretty good guides. I am an installer of viper alarms and i could mail you a couple install guides and also a whole sheet that tells you where every wire in an s2000 is located and what colors they are. Its the same info i use on all my installs. Its very simple. I would only ask for like 10 bucks
Old Apr 12, 2007 | 06:36 AM
PJK3's Avatar
bah -- $10 for that? unless it is costing you $10 in S&H, i can't see that being appropriate.
that whole "sheet of connections" is already listed on this forum several places (including linked in the FAQ under #Alarms).
here's a copy of it:
[QUOTE]12volts white (x2) + ignition harness
Starter blue/white + L of column, lt blu 24P plug
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition black/red + ignition harness
Third Ignition N/A
Accessory white/red + ignition harness
Second Accessory N/A
Keysense red/white - ignition harness
Power Lock pink/black 5wi keyless entry module
Notes: The keyless entry module is located in the driver kick behind the start button.
Power Unlock yellow/green & pink/blue 5wi keyless entry module
Lock Motor pink/black 5wi keyless entry module
Unlock Motor yellow/green 5wi keyless entry module
Parking Lights+ red/black + keyless entry module
Parking Lights- blue - headlight switch
Hazards same as turn signals
Turn Signal(L) green/red + steering column
Turn Signal
Old Apr 12, 2007 | 08:13 AM
imdarkrider's Avatar
lol thanks for using my info PJ
team510
Jan 14, 2012 10:24 AM
SlowTeg
Nov 3, 2010 12:16 PM
kian2232
Jan 7, 2010 09:33 PM
broilmebk
Jun 3, 2007 03:21 PM
trendy26
Mar 2, 2004 07:45 AM
