Alpine 4v pre-outs and JL 450/4
Old Jan 22, 2006 | 10:16 AM
bimmer convert's Avatar
Default Alpine 4v pre-outs and JL 450/4
I have an alpine 9855 which has 4v pre-outs. I'm using a JL 450/4 to power my whole system. Alpine type R components up front and a WLaurent enclosure with an Audiobahn AW100T. (The sub arrives this week - for now I'm using my old kicker S5 enclosure from my last car)
Anyway - the amp seems to work great sans 1 minor issue. The manual says the "low voltage" input is for 200mV to 2V, and the "high voltage" is for 800mV to 8V.
Anyway - I like to have the sub on the HU set to about 60% to give me headroom to turn it up or down a little as desired. However, I believe this attenuates the signal and hence, lowers the voltatage. This means that it's probably closer to 2V at 60%, and 4V at 100%... SO here's the question, do I
a - set the JL to "low" and adjust the input gain accordingly
b- set the JL to "high" and turn the amp gain all the way up (only way to get to not get drowned out by the fronts)
Right now I'm going with (a), but I'm concerned about overdriving the input stage since it's set to operate at 2V or below.
Thoughts?
- R
(edited for rampant spelling errors and typos)
Old Jan 22, 2006 | 10:24 AM
hukares's Avatar
Yuor right about how it works, set it to the 800mV to 8V input. You'll always fall in that range.
Old Jan 22, 2006 | 12:23 PM
Switchted to "high", upped the gain (about 90% on the JL, and sub at 12/15 on the Alpine), and turned down the fronts a bit. It's all balanced much more nicely now.
bimmer convert
Jan 31, 2006 02:01 PM
japwhiz
Oct 8, 2005 05:44 AM
s2khondaimport
Apr 8, 2005 09:08 AM
pikkashoe
Nov 21, 2004 02:41 PM
NFRs2000NYC
Aug 15, 2003 08:58 PM
