Alpine iDA-X001
Old May 7, 2007 | 11:34 PM
  #121
Romeez's Avatar
Originally Posted by NFRs2000NYC,May 7 2007, 11:06 PM
To those that already have this unit.....
Do you need a new model IPOD (color screen that plays video models) to get info on the alpine screen, or is it just reading tag information, and will work with the OG click wheel models?
I believe it is only 4th gen and up
Old May 7, 2007 | 11:41 PM
  #122
NFRs2000NYC's Avatar
You are correct. Just checked the manual. Thanks a lot!
Old May 8, 2007 | 12:30 AM
  #123
OverstS2k's Avatar
has anyone used an external hdd with this thing?
Old May 8, 2007 | 12:32 AM
  #124
Picturepro's Avatar
DCI install with SCV
has anyone hooked that up? Alpine / Honda / DCI with SCV to a iDAx001??
installing it Tuesday 11AM
the install tap n press has me a little confused and settings for SCV
maybe the shop will be better at this
Old May 8, 2007 | 12:42 AM
  #125
L-X's Avatar
L-X
Originally Posted by HankookS2K,Apr 28 2007, 07:19 AM
the ipod fits in the glove box...that is where i have mine. beware of the install to run the cable to the glove box...its a pain...if anyone needs help let me know
Can you shortly explain, how to run the ipod/USB-cable into the glove-box?
I'd like to do it like that way:
Is it really that difficult!?
Are there any other suggestions to hide the ipod, maybe under the dash or sth. like that?
thanks
L-X
Old May 8, 2007 | 04:23 AM
  #126
Dave-ROR's Avatar
It's easy to mount it there, but the door won't sit perfectly flush when closed.. because of that I put mine in the secret compartment but it's a hell of a lot more work and not really worth it.
Old May 8, 2007 | 04:58 PM
  #127
Picturepro's Avatar
Proud owner of a new iDAX001
I'm stumped on the dci and scv, I have a mental block Help anyone?
I hit Audio control and channel - they both work the same.... am > fm > ipod
Old May 8, 2007 | 06:13 PM
  #128
philbert's Avatar
post some pics of your new install!!
Old May 8, 2007 | 08:42 PM
  #129
HankookS2K's Avatar
thanks
L-X
its a pain....you have to remove both plastic panels behind the seats, remove the center console, then various screws that hold the glovebox in. then there are some screws in the back of the glovebox where the convertible top sits. The screws are behind a panel that clips into the back of the glovebox and its a pain to get out unless you take the convertible tray out. Then you have to run the cable underneath everything into the glovebox.
If you really wanna do it then let me know and i can guide ya through it and let you know about all the screws and what not. I have mine mounted inside the glovebox sitting in one of the compartments from the modifry glovebox organizer. You have to drill a hole into the back of the glovebox ...but you can make it look really clean if you take your time. Ill post pics tomorrow of the install.
Has anyone else mounted it somewhere else besides the glovebox?
Old May 9, 2007 | 04:24 AM
  #130
Dave-ROR's Avatar
I mounted mine in the secret compartment, how-to (sorta) and pics were posted in the DIY AP2 head unit install guide (which I think is in the faq, otherwise just search for DIY AP2)
