Alpine IDA-X100 HELP!
Old Jan 18, 2010 | 10:28 AM
Boost76's Avatar
Default Alpine IDA-X100 HELP!
I got a Alpine IDA-X100 & when I hook up the speaker wires & turn it on there is barely or no sound @ all from the speakers. When I switch the HU out, because I also own a IDA-X001 the speaker then works. Is there something wrong with my IDA-X100? Or is there something I didn't not adjust>? It does this with the tuner, USB storage, IPOD & Aux. When I turn the volume all the way up you can hear the music but barely. Any help will be greatly appreciated. Thanks.
Old Jan 18, 2010 | 11:27 AM
lovegroova's Avatar
Is the "Power IC" set up correctly? This function turns off the internal amps - see page 22 of the manual here http://vault.alpine-usa.com/products/docum...OM_IDA-X100.PDF
Old Jan 20, 2010 | 07:23 AM
Boost76's Avatar
^ tried that also. I can barely here the music then when I switch IC to off the music is gone. When I switch it back on I can barely hear it. Do you think something is wring with my internal amp? Also when I turn the engine on(just found this out) there is MAD distortion.
Old Jan 20, 2010 | 11:26 AM
ace123's Avatar
a bad ground would be my first guess, based largely on the distortion when the car engine is running. try regrounding it.
if that doesn't work, i'd try pulling the headunit, then connecting only power, wire, ignition, and one speaker at a time (with the headunit out of the dash). that will eliminate wiring and such from the equation. if your old headunit works and the new one doesnt under those conditions, you've isolated the problem to the headunit itself and you know that's the problem. if it does, you know the problem is elsewhere and you have to find it using similar techniques.
Old Jan 20, 2010 | 01:33 PM
Boost76's Avatar
^ I gave up.. couldn't figure it out.. I will try it on my 240sx Vert & see if it works on that one.
tripride
Sep 8, 2008 08:36 PM
TheLoons12
May 27, 2008 01:06 PM
Hwy 17
Nov 7, 2007 05:04 AM
TOYCLOSER
Aug 28, 2006 08:00 PM
RST
Sep 27, 2005 06:14 AM
