alpine installation questions
Old Aug 11, 2005 | 11:47 PM
mikecl713's Avatar
Default alpine installation questions
what is the 12vdc memory part from the oem harness used for?
is the audio interrupt lead the ATT??
Old Aug 11, 2005 | 11:57 PM
sctyboy's Avatar
12vDC memory should be the 12v lead that is "always on" (that is, not switched off when the ignition is). This keeps constant power to the unit to allow it to save things like presets.
ATT, short for "attenuate" is not quite an interrupt, as it technically reduces the volume by a great deal, not quite "interrupting" it completely, but yes, it should be the same, or similar, for whatever purposes you need.
(so, in short, 12v memory is the non-switched 12v lead and, yes, audio interrupt and ATT are the same thing)
Old Aug 12, 2005 | 12:02 AM
mikecl713's Avatar
thanks for the late night answers!!
Old Aug 12, 2005 | 04:30 AM
spider2k's Avatar
Active Streak: 30 Days
you cant tie the mute fro8m the car directly to the radio. the car is 12v on mute and the radio input is a ground. you'll have to use a relay.
put the car lead on 85, the 86 post to ground as well as 87. 30 to the radio input.
Old Aug 12, 2005 | 12:56 PM
modifry's Avatar
Honorary Member
You are correct that ATT is an abreviation for attenuate, but on an Alpine the ATT wire actually performs an 'interrupt" or "pause" function. It completely shuts off the audio and pauses CD playback. The hand-held remote MUTE button on the other hand, does not mute the sound, it attenuates it.
Old Aug 12, 2005 | 01:01 PM
sctyboy's Avatar
Thanks for chiming in, Modifry. I apologize for steering the original post in a somewhat wrong direction.
Does that ATT = pause go for all the alpine models? I've never had an alpine myself, but a lot of my buddies (which means I have to install them) do, just curious.
Thanks
fin man
Jul 22, 2014 08:59 AM
surfymark
Jan 21, 2009 01:01 AM
wickerbill
May 1, 2006 07:06 PM
SilverstoneS2k_FL
Oct 17, 2005 08:32 PM
Kibro
Sep 19, 2001 05:40 AM
