alpine sub, mtx amp
the alpine srs 10" is a 4ohm sub. the mtx tc3001 is rated at 150w at 4ohm and 300W at 2ohm. if i get these two, will only 150w from the amp be powering the sub or all 300, even though the ohms are different. and will there be a noticable difference. i like this amp 'cause its small
You will only get 150w. Unless you buy two subs, wire them in series. This will drop the ohm load down to 2 ohms, drawing all 300w from the amp, and the amp will run hotter. But it will still be only 150w going to each sub.
DangerZone9K
Feb 10, 2011 04:06 PM
