AM on my Alpine
Old May 11, 2006 | 12:12 PM
s2kdarren's Avatar
Default AM on my Alpine
this is my second alpine HU and my am is very very very very weak when i turn the car on and makes poppy sounds when i use the signals and 90% of the time its just complete static....
any solutions??? my stock HU recieves Am just fine....
Old May 11, 2006 | 12:22 PM
9k = heaven's Avatar
Listen to FM?
s2kdarren's Avatar
tried that but I need my hovkey games and traffic news!!
Old May 11, 2006 | 12:53 PM
xviper's Avatar
Did you supply power to the amplified antenna?
Old May 11, 2006 | 01:06 PM
s2kdarren's Avatar
^probably not cause i dont know what your tlaking about dave
Old May 11, 2006 | 02:03 PM
xviper's Avatar
The stock HU has a power lead that supplies 12V power to the antenna. That's needed to boost the AM signal. With aftermarket HUs, you don't always retain that power lead. Without power, the antenna doesn't get you AM very well.
On the wiring bundle behind the HU, you should see a YEL/GRN wire. This wire needs 12V power that comes on when the radio is on.
Old May 11, 2006 | 02:08 PM
wickerbill's Avatar
Did you use the harness adapter for honda? I had this same problem a few weeks ago with my new alpine. You should have a power antenna wire coming off the alpine harness that came with the radio. Hook that wire to the power antenna wire on the honda harness adapter and it should work. Our antenna needs some power for it to work well and that wire is what does it.
Old May 11, 2006 | 04:28 PM
s2kdarren's Avatar
thanks guys
Old May 11, 2006 | 07:06 PM
NFRs2000NYC's Avatar
Alpines will not turn on if the antenna is NOT plugged in and powered. So if it turns on, youre powered.
(unless we are talking about two different things)
dudevolley
Jun 17, 2006 04:09 AM
Y2K1S2K
Jul 21, 2004 10:18 AM
burnmacs
Apr 7, 2004 08:01 AM
stockae92
Jan 16, 2003 12:05 AM
stockae92
Dec 14, 2002 11:48 PM
