New H/U and no.....
Old Jun 15, 2006 | 07:25 PM
dudevolley's Avatar
Default New H/U and no.....
AM radio? I checked the antennae and it's screwed in all the way on the rear and pushed in all the way in the rear of the H/U. WTF is going on here? Any ideas?
Old Jun 15, 2006 | 08:50 PM
oth's Avatar
oth
yeah, it's almost always because the power antenna wire isn't hooked
up - the antenna is amplified.
Old Jun 16, 2006 | 04:16 AM
dudevolley's Avatar
any suggestions? I didn't see a wire for the antennae in the harness......
Old Jun 16, 2006 | 04:29 AM
CIVICTOS2000's Avatar
Power antenna????
Old Jun 16, 2006 | 04:30 AM
but you do get FM ok ?
Old Jun 16, 2006 | 04:38 AM
dudevolley's Avatar
FM comes in ok. I think he meant that the antennae on the new HU needs power b/c it's amplified....i'm not sure
Old Jun 16, 2006 | 12:19 PM
oth's Avatar
oth
the little stub antenna on the s2000 has an amplifier which needs power.
if you used an adaptor harness that plugs into the factory radio harness
in the car, the wire is most likely blue, and either needs to be attached to
the power antenna wire from your new headunit (if it has one, which
most do) or another power source. some installers look at the antenna,
see that it doesn't go up and down, and assume they don't need to connect
the wire (which is wrong).
Old Jun 16, 2006 | 12:47 PM
dudevolley's Avatar
I'll be tackling that tonight. Thanks for the input
Old Jun 17, 2006 | 04:09 AM
dudevolley's Avatar
FM is stronger and AM is back...thanx for the tip.
boony1968
Nov 9, 2013 05:45 PM
patinum
Mar 13, 2009 12:16 PM
goldenfri
Jul 6, 2007 06:49 PM
s2kdarren
May 11, 2006 07:06 PM
stockae92
Jan 16, 2003 12:05 AM
