which amp?
Old Dec 1, 2004 | 04:18 PM
Aze85's Avatar
Default which amp?
I was wondering which amp would be a really good match for the Infinity KAppa Perfect 6.1. I will have a stock head unit, but will most likely change it later on. does having a stock head unit affect sound quality? Also, i plan of putting the amo under the passenger seta, is that ok?
Old Dec 1, 2004 | 05:15 PM
SCoach's Avatar
You should try searching a bit as the stock HU quality question comes up quite often. Short answer, yes, it affects sound quality a LOT.
Have you taken a good look under the passenger seat? There are VERY few amps that will work under there. I'm not saying there aren't any, but its a pretty small space. Buying an amp to fit under there, provide good power, and still run cool, is going to cost some serious $$$.
Why not take a look around the electronics section, do a search, and see what others have done. There are a lot of places to put an amp in this car.
Old Dec 1, 2004 | 07:17 PM
Aze85's Avatar
search?!?!?!?
do you understand hoiw incredibly lazy i am?.... jk
will do
Old Dec 2, 2004 | 10:34 AM
TR-S2K's Avatar
Driver seat has a lot more room under it than passenger seat. I had my amp installed under driver seat without any ventilation problem.
Old Dec 2, 2004 | 10:55 AM
KaCee's Avatar
Amp model and/or size?
Old Dec 2, 2004 | 11:12 AM
TR-S2K's Avatar
The amp is Memphis MC2004 4-channel with 50W/ch.
The largest amp can be fitted under driver seat without ventilation problem and the seat can be adjusted: 10"x12"x2"
Old Dec 2, 2004 | 03:02 PM
Aze85's Avatar
how do you like the sound? is it powerful? are the low bass notes hit well?
Crazy_Schizo
Mar 23, 2009 07:38 PM
Luckyaze
Jan 7, 2008 06:29 PM
bhav
May 10, 2006 12:23 PM
SolReborn
Mar 30, 2005 08:29 PM
Mocky
Nov 2, 2004 11:56 AM
