Speaker amp placement
Old Jan 7, 2008 | 03:53 PM
Luckyaze's Avatar
Default Speaker amp placement
I'm planning on placing my amp under the passenger seat, is this a good idea, anybody try this and have any problem at all? Thanks.
Old Jan 7, 2008 | 04:48 PM
05S2KinClovis_CA's Avatar
Try sliding your arm under there...you may reconsider. I know some have placed an amp under the drivers seat but it's still cramped.
Old Jan 7, 2008 | 05:38 PM
Luckyaze's Avatar
let say the amp fit tightly, would this compromise any air circulation?
Old Jan 7, 2008 | 05:46 PM
Yes it would...amps usually require some air space to cool adequately. If the seat is resting on the amp it will heat up a bit more. Electronics suffer from excessive heat and the life of the internal components will be compromised. How much shorter will the life be..... ...who knows. I know for every 10 deg higher temp the components life will be cut in half.
Others have done it with success...I wouldn't...
Old Jan 7, 2008 | 06:29 PM
Luckyaze's Avatar
thanks for the reply, i'll just get longer rca cable.
MurderS2K
Feb 23, 2010 08:53 PM
jwa4378
May 16, 2006 07:52 AM
Craigyboy
Mar 23, 2006 03:30 AM
Mocky
Nov 2, 2004 11:56 AM
FRCHNDN
Mar 12, 2001 09:50 AM
