Amp Choices?
Old Jan 15, 2005 | 08:15 AM
kw2000's Avatar
Default Amp Choices?
aight this is what im getting and im trying to decide what amp to get
heres what i have
Alpine 9827 Headunit
Polk MMC6500 Pair Speakers-
Power Handling (continuous) 125 w
Power Handling (peak) 250 w
Polk MM2084 8
Power Handling (continuous) 200 w
Power Handling (peak) 400 w
Im thinking of doing a Polk Amp the 4 Channel C400.4
C400.4-
Channels 4/3/2 (bridgeable)
Total Dynamic Power (all ch. driven) 975 watts
14.4 Volts RMS Not Bridged @ 1kHz
4 Ohms 75 watts x 4
2 Ohms 100 watts x 4
14.4 Volts RMS Bridged
4 Ohms 200 watts x 2
Would this 4 Channel amp all i need if all i wanted was the Speakers in the panel and the 2 subs? or would it only be good for Speakers? Should i buy 2 seperate amps?
Old Jan 15, 2005 | 09:18 AM
Cubs2k's Avatar
What is the impedence of the 8 inch subs you have?
if they are 2 ohm, you may want to wire them in series and run them on a bridged channel....
I'm not familiar with Polk products, but you could use this amp for all the speakers you mentioned, and is very flexable in terms of configuration.
I have a Alpine amp 4/3/2 running the doors and sub in 3 channel mode....I'm very happy with it.
Jeff
Old Jan 15, 2005 | 07:03 PM
darkknight1999's Avatar
That equipment will be just fine for your needs and will work well together.
I checked the specs on it and your fine. Follow the manual for hooking up the speakers. If you have any questions let me know.
CreAziaN
Jun 25, 2010 10:34 AM
s2krazy01
Jul 11, 2007 09:44 PM
Hero
Apr 24, 2006 06:32 PM
vodalus
Feb 13, 2003 08:07 PM
mgiang7
Feb 13, 2003 12:20 PM
