Amp with Crossovers
Old Jun 2, 2005 | 09:40 AM
AxeAngel's Avatar
Default Amp with Crossovers
I don't want any flaming.
Just want everyone's opinions. I currently have 3 amps installed in my S of which only 1 has internal x-overs.
Personally I don't see the need of having built in crossovers in my setup, 2 of the amps each run a set of components(that each have a set of x-overs), the third runs a sub and a set of bass shakers.
If you are running crossovers downstream of the amp and a good eq upstream from the amps what's the purpose of the builtin x-over. Is this just something for ease of mind for those running lower quality speakers? ie those running coaxials or other non-crossover setups?
Any benefits to producing cleaner sound with less THD? O
Old Jun 2, 2005 | 10:10 AM
TR-S2K's Avatar
Most components have frequencies range of around 50Hz to 22kHz. The amp internal x-over should be set at high-pass and x-over point at 50Hz to prevent lower frequencies feeding the components. For sub-amp, the x-over should be set at low-pass and x-over point should be 50Hz or so. This is assume that your HU does not have sub-woofer output to drive the sub-amp.
Old Jun 2, 2005 | 10:43 AM
AxeAngel's Avatar
that's what im set at. HPF for front and rear from HU. High setting on both comp amp and low setting with lower x-over point to the sub. and yes HU has a dedicated sub-output
Just wanted to hear everyone's opinions and in particular certain knowledgeable people on this board that love to flame.
scorcher
Aug 15, 2010 01:50 PM
s2Keanenk
Feb 6, 2008 01:58 PM
Brutewes
May 16, 2006 11:37 AM
littlerocket777
Mar 5, 2006 11:00 AM
steve0617
Mar 8, 2004 12:42 PM
