Amp drawing to much power?
Old May 6, 2008 | 11:09 AM
xrapidx's Avatar
Default Amp drawing to much power?
I added an amp to my stock radio, and upgraded the speakers... except now when I do certain things, like use the accessory socket, or set the side mirrors, the radio dies. Is this battery to weak? Or should I be looking elsehwere?
Old May 6, 2008 | 12:36 PM
3ngin33r1's Avatar
Go to your local autoparts store, they'll test your battery. Check your alternator too.
If that's not it, you probably have a wiring problem somewhere, bad ground maybe or something.
How big is the amp?
You may want to ask in the electronics forum.
Old May 6, 2008 | 12:52 PM
RayRay's Avatar
Yeah that should not be happing, sounds like you have a wiring problem, how did you hook it up?
Old May 6, 2008 | 01:01 PM
HonCBRf2's Avatar
This might be a stupid question, but you did run the power for the amp to the Battery right?? Believe me, when I was installing car audio, you wouldn't believe the shit I've seen some people do.
Old May 6, 2008 | 01:26 PM
knlg's Avatar
Like HonCBRf2 said, you have to draw power straight from the battery. Also, it's not really a battery problem. If this is a monster of an amp you installed you may need to upgrade your alternator. But thats unlikely, sounds more like a wiring problem like others have stated.
Old May 6, 2008 | 01:31 PM
Tharg!'s Avatar
No way yer Radio power should be going out. If your amp was too much for the battery (Alternator) (And assuming as stated above you hooked it TO the battery) it would drain the battery and you would have issues w/ comming back out to yer car and not having enough juice to start it.
So as per above, sounds like somethin ain't installed correctly.
J/Tharg!
Old May 6, 2008 | 02:26 PM
K-Lo's Avatar
should't be the case. i know my battery is downhill already but i still installed a Kenwood KAC-7204 today with no problems.
Old May 6, 2008 | 11:15 PM
xrapidx's Avatar
Thanks for the replies, I didn't do the install, took it to an audio place a while back.
I'll ask them what its connected to. There's also a Sony MP3 CD Shuttle in the boot that needed power.
The amp is a 2-channel Sherwood XAT-120.
I'll check if its the actual headunit that looses power, or just the amp, I've always assumed its the headunit...
Old May 7, 2008 | 06:38 AM
HonCBRf2's Avatar
I would take it back and have them recheck their wiring, sounds like you might have a short somewhere in the wiring. You can actually look at your battery to see if they ran it to it, it should have another large RED wire coming off of the positive terminal as well with the stock power wire.
Old May 7, 2008 | 06:57 AM
xrapidx's Avatar
I'll have a look this evening...
Crackerballer
May 19, 2009 12:52 PM
s2krey
May 9, 2008 02:10 PM
cshamash
Mar 4, 2006 08:22 AM
sweetj
Oct 14, 2004 07:09 AM
