Attaching amp power wire to battery
Old Mar 4, 2006 | 06:12 AM
cshamash's Avatar
Default Attaching amp power wire to battery
Do I need to use a proper battery terminal to attach the amp power wire to the battery or can I get some sort of crimp on ring connector from radio shack ?
Also say I have a amp rated at 30 amps do I use a 30 amp fuse or a higher rated fuse?
Thanks
Old Mar 4, 2006 | 08:22 AM
hukares's Avatar
I'd reccomend that you get a proper battery terminal but using a ring terminal will work fine too. you can hook it to the battery terminal or to the stud in the fuse box. I don't have any pictures, maybe someone here will.
Unless you have more than just the 1 amp attached, use a 30 amp fuse.
s2krey
May 9, 2008 02:10 PM
xrapidx
May 7, 2008 06:57 AM
droo587
Mar 16, 2008 09:50 PM
billyjoho
Nov 30, 2006 08:23 AM
S4 Mike
Jun 23, 2002 12:19 AM
