Amp Question
Old Mar 21, 2007 | 09:07 PM
Yatzee's Avatar
Default Amp Question
So I hooked an amp up and am running an Ipod off it w/o a headunit. My question is when I first hooked it up the amp wasn't turning on then i put power to where the headunit wire should go and it worked. Is it bad to run it this way, will I ruin something, and is there a better way to do it?
Thanks, Alex
Old Mar 21, 2007 | 09:13 PM
NFRs2000NYC's Avatar
Yes it is, unless you ran it to the ACC wire, which will shut the amp off when the car is off. However, its still a weird way of doing it. Why dont you have a headunit?
Old Mar 22, 2007 | 08:09 AM
Yatzee's Avatar
Its in a friends GEM car which is a street legal golf cart and we wanted to do it clean and simple so nothing would be visable to get stolen.
Old Mar 28, 2007 | 08:25 AM
other_vortechs2k's Avatar
You could run power through a relay which is switched by the turning the key on. Will that work for you?
Old Mar 28, 2007 | 06:31 PM
PJK3's Avatar
or just set up an inline switch from a 12V source to the remote turn on. but if you forget the switch on, it will drain your battery.
no problems doing this aside from battery drain issues if you leave the amp powered on.
on an out of the box clever idea.
s2krey
May 9, 2008 02:10 PM
Boost76
Feb 15, 2008 07:35 AM
chunkotron
Nov 13, 2007 12:01 AM
S2000GT
Sep 23, 2005 09:45 AM
bertsirkin
Dec 22, 2002 03:37 PM
