Amp question & system set up
Old Aug 15, 2005 | 10:33 AM
jwa4378's Avatar
Alphasonik is a good brand. I would wire both amps at once, if you can. I would rather do it all at once, because you have to yank out the HU for the RCA's, run new power wires, run new ground. This gets kinda old the 2nd time. Especially since you cannot run RCA and power wires next to eachother (RCA's down center console and power down door sill).
I also do not think you will be able to even really hear the sub at all with only 120WRMS running to it. My 283WRMS is kinda under-whelming at times. Most people run between 250-400WRMS.
John
Old Aug 15, 2005 | 10:51 AM
DaPutster's Avatar
I have the Polk MMC-6500's, and they fit perfectly with the spacer bracket included in the box. The only issue with them is fitting the tweeters in the stock location. Take your time when mounting them in the pod & use the stock bracket to hold them in place. Its tight, but they do fit.
Old Aug 15, 2005 | 12:00 PM
sctyboy's Avatar
Don't mean to nitpick, but just want to make sure you get those crossovers wired right when you do it. The crossover is going to be wired in before both the mid-range and tweeter, not in between them.
You sound like you know what you are doing and just had a brain-fart on the drawing, but better to get it out of the way now
[CODE]
Old Aug 15, 2005 | 12:12 PM
Saki GT's Avatar
[QUOTE=sctyboy,Aug 15 2005, 12:00 PM] Don't mean to nitpick, but just want to make sure you get those crossovers wired right when you do it. The crossover is going to be wired in before both the mid-range and tweeter, not in between them.
[CODE]
common reactor
Jul 31, 2006 12:28 PM
kikicha
Jul 23, 2006 09:12 PM
bborzell
Oct 4, 2005 11:15 AM
hornyhonda
Oct 31, 2004 10:34 AM
Portland
Jun 28, 2003 03:42 PM
