amp turn on lead for stock head unit
Old Aug 4, 2003 | 07:49 PM
ankuse's Avatar
Default amp turn on lead for stock head unit
Was there ever a consenses of where to hook up the turn on lead, i am keeping the stock headunit, i just need to know where to ttap the amp turn on lead to? I am planning on putting the amp underneath the passenger seat. I have a blaupunk pa275 and will be using speaker level inputs, I know some amps don't need turn on leads, if u use speaker level inputs, but i don't know if that is the case for this amp.
thank
ankur
Old Aug 5, 2003 | 08:30 PM
dierk's Avatar
Do you have access to the owner's manual for the amplifier? Does it not answer this question?
Blaupunkt seems to be a fairly large company. They might have a tech support line or email address where you can find the answer.
Good luck and let us know what you find out.
Old Aug 5, 2003 | 08:38 PM
WLAURENT's Avatar
You can tap in behind the radio - it is a green/yellow wire that has a funky connector on it where it connects to a larger gauge wire of the same color.
You can also tap in to the same wire by pulling the panel from behind the passenger seat - it is right there.
Old Aug 6, 2003 | 05:55 PM
ankuse's Avatar
i had read some posts that said that the antenna lead has no power when the cd player is one?? so i was just wondering if that was the same wire lead.
thanks
ankur
Old Aug 7, 2003 | 07:36 AM
WLAURENT's Avatar
thanks
ankur
I ran an amp off of it (trhe turn on lead that is) with no problems.
Old Aug 8, 2003 | 08:54 PM
ankuse's Avatar
i stripped the wire, and used a volt meter, and it has power thru it when the raddio thurns on, but as soon as you turn on the cd player, it drops in volts, to like nothing, so i had to electrice tape that back up and wound up using the accessory 12 volt wire, behing the headunit as to solder in the remote run on lead.
ankur
Old Aug 9, 2003 | 11:40 AM
WLAURENT's Avatar
ankur
Interesting - thanks for clarifying.
My amp seemed to work fine using it as a turn-on lead. Perhaps my amp was also sensing input signal?
deanjones
Aug 11, 2005 03:55 PM
JDMpress
Jul 13, 2004 06:56 AM
145
Jul 9, 2002 06:06 PM
DJ Qube
Jun 2, 2001 10:34 PM
saliv8
Oct 30, 2000 03:43 PM
